CruzinBobs's avatar
CruzinBobs
Atwood G6A 8E
I just bought a 2000 Dunes by Curtis 27' 5th wheel toyhauler. It has the Atwood G6A 8E Electronic ignition water heater. When I turn to switch to on, no light comes on. I have googled problems and cleaned the igniter and connections with no change.
I'm not very handy with electronics but I metered the wiring at water heater and it appears to have power when switch is turned on. And no Power when switch is off.
Any help is greatly appreciated.
  • CruzinBobs wrote:
    I'm sorry, I didn't say that the water heater does not light and is propane only.
    Yes the light problem could be burnt out switch light.
    Do my test and then see if the Light is inop. Doug
  • Check and see if there is 12v coming to the water heater, it must have 12v to work.
    Dusty
  • I'm sorry, I didn't say that the water heater does not light and is propane only.
  • Turn the LP tanks OFF. Fire up the Water Heater on LP. Within 10 minutes that light will be ON:B Indicating the system is functioning as designed. I assume your LP Water Heater IS lighting? You did not state that. Doug
  • That light on the On/Off switch is a FAULT Light
    It ONLY comes on when there is a FAULT
    1) The main flame FAILS to light off and prove that it lit.
    Main flme lights a milivolt signal is generated (flam ionization) and that signal goes back to circuit board 'proving' main flame lit.
    No signal received then circuit board shuts down 12V DC to gas valve....will make 3 attempts to light & prove main flame. After 3X it 'locks out; and triggers FAULT light to alert owner of problem.
    2) Anytime the ECO OPENS (Energy Cut Off--Hi Temp t-stat)
    IF T-stat (normal temp 140*F) ails to open then the ECO OPENS when temp reaches 180*F shutting down heating cycle.
    ECO opening triggers FAULT light. ECO self resets when temp drops below 150*F and owners has to reset FAULT light
    To reset and make further attempts to light off you turn On/OFF switch OFF wait 30 sec and then turn back on.
    BLUE Wire is FAULT light...
    Suburban light turns on.....then turns off when main flame lights.
    Fault light stays on if main flame fails
    Different schemes......
