Sam_Spade
Sep 25, 2016Explorer
With the system all closed and under a slight pressure from the pump, as the water in the tank heats up the expansion puts the entire water system under MUCH MORE pressure.
This goes back to "normal" once a faucet is opened.
The weak spot in mine is the pressure relief valve mounted on the heater tank (old valve and new one both).
It would appear that the extra pressure has found a different weak spot on yours.
Hopefully a few experiments can find where the leak is actually coming from......and it probably is NOT at the water heater itself.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
