ezgoin
Sep 25, 2016Explorer
Sam Spade wrote:
Hopefully a few experiments can find where the leak is actually coming from......and it probably is NOT at the water heater itself.
I am leaning this way right now. The water heater sits 10-12" below coach floor, so I'm assuming the leak must be from a connection under the sink cabinet caused by the pressure created by heating the water. (No water leaks out from under the cabinet with the heater off, not even when using the sink.) Problem is...how do I access any plumbing connections hidden under the cabinet. Directly under the sink where the lines come up are boxed in with no way to look underneath and next to the sink are drawers that have a wall between them and the sink. ?????
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
