ezgoin's avatar
ezgoin
Atwood gas water heater leaks when turned on
Turned on my Atwood 6 gal gas water heater yesterday to heat water for the day and about 15-20 minutes later I had water leaking under bathroom sink cabinet which is almost directly over the heater. Shut it off, dried up the water on the floor and no more leak. No leaks when turning on hot or cold water faucets so the water lines don't leak. Only leaks when heating up. No leaks or drips outside under the heater or coach, so it only leaks UP into cabinet under sink, which I have no access to. Any ideas? Will the heater have to be removed for examination?
The top of the tank is about 10" below floor level of the coach and if the hot cold feeds don't leak when turned on, what other line is running up from the heater that could be leaking ?
Appreciate any ideas or comments. Thanks!
    Yes. Not difficult but does take a bit of time. Assuming the water line fittings themselves aren't the source of the problem the aluminum tank itself is either split or there could be a hairline crack in the welds where the water lines connect to the tank. I helped a friend remove his Atwood water tank with this exact issue, fortunately in his case the hairline crack was successfully welded. If in your case you determine that welding isn't practical the good news is that Atwood does sell replacement tanks, with Suburban you'd have to replace the entire water heater. BTW, in the process of removing the tank you'll destroy the gaskets and rings that hold the tank in place to the mounting plate ... new replacement tanks include this ring & gasket kit but if you manage to repair your original tank this ring & gasket kit can be ordered from any RV dealer.
  • Maybe the PT valve is bad and the overflow pipe is leaking. Just a guess.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
