Grit_dog
Feb 07, 2022Trailblazer
dougrainer wrote:
To those that feel you can weld a Atwood tank. Usually the "burst" is so extreme, that to remove the water heater from the RV, you have to destroy the Styrofoam Insulator blocks. Once welded, you then have to find new Insulator blocks. I don't know if anybody sells just the Insulator styrofoam blocks. Also a New replacement comes with the 2 round trim rings that secures the inner tank to the metal front. I also don't know where you can get those rings without buying a replacement tank. It is better to just buy the replacement tank assbly. Doug
Lots of "creativity" from this group for sure.
Busted water heater tank = figure out how to remove it and install a new one, IMO.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
