bmwdriver2019
Feb 15, 2022Explorer
to those who have read my post, let me ad that the engine coolant never comes in contact with the rv water system , all the heat exchanger is a short angled tube which the to and from coolant lines connect to , thats it, the tube is externally mounted outside the tank , , no in order to replace the tank , the heater must be removed from the vehicle, disassembled , repaired or replaced the leaking tank , and put back together , and hopefully ALL GOES WELL,
after much research i had found that dometic makes a replacement for the atwood unit , part number 96163, same specs as the atwood , i really dont care that there are numerous trailers and 5th wheels out in the field, but there are numerous motorhomes using the atwood system , and it was a good one, i simply dont care for what dometic did , they bought atwood and discontinued most of their product and water heater line, and many were models with motor aide, its not the point, its what they did , very simply they could have made a slight modification , and have as a kit a motor aide ad on, attached with stainless steel clamps to support the motor aide fitting to the tank , and styrofoam sections, , and two hose clamps , done deal , so now YOUR stuck with a choice they made , and you have a expensive piece of equipment , not doing as designed to do
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
