69gp's avatar
69gp
Atwood heater problem
hi I have an Atwood heater that I am having trouble with. The heater will not stay running. Got to dark to look into it tonight but just looking for any ideas as to what it may be.
When I turn the switch on the water heater fires up and runs for about 5 seconds before shutting down. I did check the thermostats by disconnecting and bypassing them. Had no effect. I think the control board is ok because I do get a spark to light the unit.
Any clues?
  • Old-Biscuit wrote:
    That model uses the spark electrode for return path of flame signal (Flame generates milliamp signal thru rectification---which proves flame is lit)
    No return signal circuit board shuts down DC to gas valve so raw fuel does not accumulate in combustion chamber
    Spark electrode MUST be engulfed in flame when it lights off
    Spark electrode must be free of soot/carbon build up.....clean with emery cloth
    Spark electrode high voltage wire connection must be clean/tight
    Spark electrode ceramic insulator can not be cracked....ground tracking
    Spark electrode assembly screw must be clean/tight ------ground source for rod
    Spark electrode gap 1/8"
    Thanks for the Help, Had to replace the electrode. Brought the control board down to my local RV supply store and they did check it out and found that it was working properly. The electrode did look good, gave it a quick cleaning with some fine emery cloth porcelain was still shinny with no cracks in it. guess looks can be deceiving. As soon as I installed the new one and made a few adjustments it fired right up.
  • That model uses the spark electrode for return path of flame signal (Flame generates milliamp signal thru rectification---which proves flame is lit)
    First off.....
    Atwood made a lot of different models
    Some gas only....pilot manual light
    Some gas only...pilot with reigntor
    Some gas only....electronic ignition
    Some gas /electic with separate controls
    Some gs/electric combined controls \\
    Etc ETc
    Which one do YOU have ??? What year/model is it??
    Flame proving is most likely the issue. Flame lights and must prove it lit.
    Means/Methods vary
    its a 1999 model #G6A-8E with electronic ignition
  • First off.....
    Etc ETc
    Means/Methods vary
  • With our 1991 we got last year, the trouble was the little vent hole that has its own little cover in the outside door to the water heater was closed too tight. Not enough air. Opening that little cover making the vent hole bigger solved the problem. Had to get tough with it and break it open, because it was jammed shut.
    Test for that by leaving the outside door hanging open. If it all works then, and not when it is closed, then it is that vent hole.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 06, 2026
