philh
Jun 26, 2019Explorer III
How bad (fast) is the galvanic corrosion? If I drain the tank through the quick drain after every use, will this slow down the issue? How about removing the plug completely when it goes into storage, will this help?
Another thought occurred to me, does the electric water heater element contribute to the galvanic action? If you were to only heat with propane, would that significantly cut corrosion?
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
