j-d
Aug 16, 2015Explorer II
Does your Gas Valve look like
or does it have a slide across the top for Temperature Setting?
If it looks like the pic, that's the current valve. The one with the slide was problematic. I had to replace ours.
Thermocouple: There's a kit which is both TC and Pilot Orifice.
Both these images are from Amazon.
Note on the Thermocouple Connection: It LOOKS like a Gas fitting but it's actually a wire terminal. Tighten it SNUG ONLY. More and you'll crush the center core and short the TC out. It has to conduct a voltage to the Valve to keep it open. Can't do that shorted.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
