Runningfawn's avatar
Runningfawn
Atwood Hydro Fame ii
We have an 1992 Fleetwood Flair with an Atwood Hydro Flame 8535 ii
We are having problems with the sail switch failing!
What hapened is for the last 5 yrs we have had to replace the burner & igintor. Everything ran great up until a monh ago.. We would turn on & it comes on & lights then goes out in seconds. We replaced the sail switch, limit swicth. Seem to fix the problem, after a couple weeks started doing the samething. So Sail Switch limit & Control Board & Theramstat. Again worked for a few days.. So yesterday it is back to not clicking! We have checked wiring made sure clean & clear good air flow Battery is up & have Propane.. What is causing the Sail Switch to keep failing??? Please We need help!!!
