enblethen
Nov 21, 2018Nomad
Falling apart could be just missing screws. It is not hard to reattach the burner assembly into the furnace using 1/4 inch socket set and extension to get to screws. Have you removed burner assembly and looked into the furnace burner box?
Circuit boards are not bad in price from Dinosaur Electronics. Some problems is with the connector on the circuit boadr. They contacts corrode. You can clean them using white pencil eraser. Then applying electric oxidation compound. (de-ox)
Some failures on board can be seen. Black burnt spots.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
