Oasisbob's avatar
Oasisbob
ATWOOD OVEN TROUBLESHOOTING ?
Pilot light lights fine. After two minutes I turn up the temp and burner comes on heating up. Then burner goes off and oven cools. Problem is burner will not relight . I see the pilot light get brighter but flames do not exit the burner. I thought the holes might be clogged but it lights off fine the first time. Any thoughts onb what to check?
  • Thanks Don. May I ask is the thermacouple or gas valve hard to replace?
  • Try replacing the thermalcouple first. If that does not do it, then replace the gas valve assembly. Thats the only two possibilities.
