huskym1025's avatar
huskym1025
Atwood range
I have a Atwood range in my TT and while camping this past week. I was using the oven, it lit fine and warmed up the oven. I had it set to 425 degrees. While the food in the oven was cooking, I heard a popping sound coming from the oven. I looked in the oven and notice the main burner was going out and relighting off and on. I turned the oven off after noticing that. Has anyone had this problem before that could offer a quick fix? Thanks!
  • Sounds like you should light oven back off and see if you can repeat issue.
    If you can....lite stove top burners and see if they do the same thing.
    Oven and stove top......LP regulator
    Oven only (stove top burners OK)...oven control
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
