unbob's avatar
unbob
Atwood stovetop grate "melting"
After about 5 years living as a full-timer, I began to notice that the grate on my Atwood stove was in terrible condition - corroded and sagging. So I decided to order two new grates (Atwood 57190 Grate). Expensive items but really needed replacement.
After about two months of use, I noticed that the grate was sagging or "melting" directly over the burner. Not good - pans would no longer lay flat since there was no longer a flat surface. Very irritating and the main reason I replaced in the first place!
Question - has anyone else here had this problem? And, is there an alternate grate available that will not "melt"? I will gladly order a new one if guaranteed not to melt. TIA, Rob
  • I had this same issue with my older 2002 fifth wheel... Same Atwood range, same style of grates.. sagging, cracked porcelain grates... I just took a hammer once in a while and bent them back... not worth the $$ ..
  • johnhicks wrote:
    A possibility would be putting a cast iron, steel or stainless BBQ grate over the Atwood grate providing double support.
    Sorry, that won't work because the stovetop cover would no longer fit and close properly.
  • I had that problem with an older unit.
    A possibility would be putting a cast iron, steel or stainless BBQ grate over the Atwood grate providing double support. Many propane-grill grates are also porcelain-coated.
  • Gjac's avatar
    Gjac
    Explorer III
    I had a problem with the stove top itself. Repeated boil overs when making coffee cracked the white porcelain coating around the large burner which eventually came off. I replaced it with a black one but after several years it warped from the heat. The smaller burners look fine. I think excess heat builds up under a large frying pan over the large burner. The coating on my replacement grates are coming off but are not melting as you describe.
  • An interesting problem I have never heard of. Makes you wonder if they recently changed manufacturing process or moved it to some foreign locale like China?
  • Dog Folks wrote:
    There may be a problem with the grates that Atwood does not know about.
    I would contact them and complain/advise them of the problem.
    Agreed. Just contacted the retailer who sold me the grates. Hard to believe I'm the only one having this problem!
  • There may be a problem with the grates that Atwood does not know about.
