DVGaylin wrote:
Problem solved...
I replaced the Spark Electrode. No more blown fuses.
The old Electrode must have been drawing just enough current to blow the fuse with the Thermal Cut-off in but not when the jumper was in. Weird...
BTW dougrainer, you forgot one thing; using a jumper did not cause the fuse to blow. So if there was a short somewhere the jumper would have blown the fuse as well. Thanks for replying...
There is more to this. NO WAY a Spark Electrode could cause a direct short to blow a 12 volt 15 amp fuse. Please come back when the short returns. Doug
