- Old-BiscuitExplorer IIIHave you checked with an appliance repair shop for a substitution ?
Just needs to be same threaded end and comparable length - jddemersExplorerthank you for the replies...kinda what I thought.
- Darryl_RitaExplorerMust be some kind of odd-ball thermocouple. Usually the only differences between them is length and the attachment. I'd say go to a hardware store and compare the flame end with your old one. Ignore the metal clip that holds the end in the flame, as long as yours is in re-usable condition.
- SoundGuyExplorer
jddemers wrote:
I have an Atwood RV 1733 oven and the thermocouple is bad and I need to replace it but the part # 57274 has been discontinued. Does anybody know of a substitute part I can use instead?
You're out of luck ... this thermocouple for an Atwood series 33 range is indeed discontinued and there is no recommended replacement for it. :(
