BFL13
Mar 28, 2019Explorer II
Perhaps the "thermal cut-off device"? (on the incoming power wire and is connected to the thermostat) If there is an obstruction in the burner or flue tube (mud wasps, eg) it will trip. Also the exhaust grill on the access door must be clear or it can trip the thermal cut-off. The wide band on the grill must be at the bottom. If at the top, pop it out and put it in right way up.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
