road-runner wrote:
And as is all to typical, Camco says "Camco RV Magnesium Anode Rod extends the life of a water heater by attracting corrosive elements in the water, protecting the tank and elements from corrosion. This Anode Rod fits Atwood water heaters."
I'm not suggesting to believe this, just repeating what they say.
So, it is posted EXACTLY What Atwood states and you feel to post an aftermarket sales promotion?????????? Doug
"Atwood water heater tanks are constructed of a high strength aluminum.
The interior of the tank consists of a .0015 thickness of type 7072
aluminum (pure aluminum and zinc) that is fused to the core during the
rolling process. This material protects the tanks from the effects of heavy
metals and salts found in waters throughout the country. It is anodic to
these heavy metals and acts much like an anode in a steel glass lined
tank except it will last much longer. Aftermarket Anode Rods are not
required and should not be used and will void warranty
