dougrainer
Aug 21, 2016Nomad
There is a Thermal FLAME fuse by the Burner tube. That is there in case you have a Blockage(insect nest) IN THE burner flue that will cause a Flashback Flame. When that happens it may indeed melt the Circuit board and then melt that Thermal fuse. Completely check the Burner flue for blockage as that is the ONLY thing that usually causes your type problem. Doug
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
