hgpezi's avatar
hgpezi
Atwood water heater different leak
Hi I am fairly new here and I have a problem with my Atwood water heater. I checked already older posts but I could not find an answer.
Problem is that the water heater is leaking right underneath the drain plug. The drainplug is not the issue becuase it stays dry all the time. Around that drain plug is a white foam ring and the water is coming out there. I really don't know is it something bigger or is it only a gasket. Any suggestions?
I attached 2 pictures and I hope it helps to understand.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
