jetcare
Oct 08, 2016Explorer
The thermostat with the round wire terminal soldered to it is for the 16 gallon EXT water heater and is set for about 155 degrees. This is the wrong thermostat for a 6 gallon unit. You mentioned a kit that contained two identical looking thermostats. This is the kit you need. If you look at the back of the thermostats, one will say 60C and one will say 82C. The 82C is the ECO.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 18, 2026
