Old-Biscuit
Oct 08, 2016Explorer III
Fault light cause main fl;ame is not lighting/proving lit and circuit board has made 3 attempts.
When spark is firing 12VDC would be on ECO and AT gas solenoids
If this issue is occurring while using the 'round pin' t-stat (how anyone connected a spade terminal to that round pin :H)
Anyway...get the correct set of t-stat/eco and foam cover
THEN retest WH
And IF you really wan to test temp of water ...use a thermometer in a glass running straight hot water from closest faucet.
THEN retest WH
