Bobbo
Aug 26, 2019Explorer III
Was the light ever working? You need 3 connections to the lighted switch. You have the hot wire to the switch, you have the wire from the switch to the relay that turns on the 120v heating element, and you have the ground wire that is only required so the switch will light up.
If the heating element is working, then wires 1 and 2 are working. The only other possibility is the ground wire is not grounding.
(Once the switch lights up, if it is lit up ALL THE TIME, you have wires 1 and 2 reversed.)
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 25, 2026
