Old-Biscuit
May 20, 2020Explorer III
STBRetired wrote:
Check was to see if there was continuity between orange and white, not to check for continuity from switch to board. Another easy way to check would be to remove orange wire from board, turn on electric switch and check to see if 12V on orange wire.
White (electric) and Orange (gas) wires are in same multipin connector
Could pull connector off board and check for continuity between White and Orage wire PINS
Could even turn either on/off switch on and check for DC Voltage between the 2 PINS (with connector pulled off board)
Good idea!
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 30, 2026
