nazpaz's avatar
nazpaz
Atwood Water Heater gas comes on-only electric switch is on
I flushed out my water heater today. Got a lot of the white flakes out of it. I put the plug back in, turned the water on, and then flipped the 110v water heater switch. However, when I did that, the gas came on and heated it up. The gas side was turned off. If I turn 110v off and turn the gas side on, the gas lights and it heats. If I turn the gas side off and turn only the electric on, the gas lights and it heats.
It was all working fine until today.
Any thoughts would be welcome.
  • Circuit Board has shorted........
    Both gas and electric use 12VDC for control
    DC comes from Electric and/or Gas On/Off Switches to the common circuit board
    White wire is from Electric Switch
    Orange wire is from Gas Switch
    Electric is shorting across to Gas circuit...
    **2004 Atwood starting using the 'common DC control' for 6 gal & 10 gal models
Having RV issues? Connect with others who have been in your shoes.24,284 PostsLatest Activity: Jul 21, 2025
