Most common issues with DSI gas water heaters are..
1: Lack of routine cleaning of burner and related areas.. Solution, PM it.
2: Control board or other component failure (I'll lump em all in this).
To test the control board.. Remove and take to Camping World (Call first to be sure they can do it) as if anyone near you has a tester, they are suspect #1, NOTE Removal is easy, two screws, two electrical connections. One of which is suspect I might add (the high voltage one).
OR: remove and replace.
in my case... Control board died... I was unable to get a Dinosaur replacement for logistic reasons so I had to go with another OEM
If you have to replace.> Check with Dinosaur boards.. Much better boards in my not very humble opinion.
