chiefward's avatar
chiefward
Atwood water heater high pitch noise
My Atwood water heater model GC6AA-10E makes a high pitch noise when operating on electric. Is that a sign that the heating element is going bad? (Is producing hot water.) The heating element is on the back side of the unit and very difficult to get to. Any suggestions on removing and replacing the element would be appreciated.
  • Dr Jay wrote:
    Had a very similar problem with my Atwood. The noise was corrected by replacing my two one-way check valves. The noise was loud and occurred weather it was propane, electric or both.
    Friends has same issue, same repair, same result. Their noise was loud not and not a little hum.
  • Had a very similar problem with my Atwood. The noise was corrected by replacing my two one-way check valves. The noise was loud and occurred weather it was propane, electric or both.
  • That whine is NORMAL. It does the same thing on LP, but you have a hard time hearing it because of the roar of the flame. Elements will not make any noise at all, regardless if operating or going bad. Doug
    From Atwood.
    We do not have anything formally written up. This is not a defect with the water heater or components. We have a new potting on the circuit board and new circuitry underneath that causes a humming noise. This is normal in operations, and will not affect the water heater's function or any components.
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 08, 2025
