Teleman's avatar
Teleman
Atwood water heater problem
I've had issues with the water heater not igniting. I cleaned the contacts on the motherboard multipin connector surface and that worked for a while and then I had to repeat this again. It worked for a while more but now it's not helping. My concern is that repeated treatment with Emory paper may have worn the material down and a connection is broken. Or it could be something else. Anyway my inclination is to replace the igniter board. We're leaving on a short trip in two days. I have the option of running the generator to heat the water with 110 VAC or use the hot water produced when driving from the hoses coming from the engine's cooling system. Ideally I'd like to get the igniter board. Where can I get it? Would an Airstream dealer have it in stock? I'm passing one near Morgan Hill, CA on Monday. Our coach is a 2000 Airstream Land Yacht. It is the Atwood 91367 circuit board. Appears to be fairly common.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 14, 2025
