Katdaddy's avatar
Katdaddy
Explorer II
Nov 08, 2023
Solved
Atwood water heater problem
We have an Atwood water heater. Ours runs on propane. On our last trip it had an issue that I have never seen before. It would start as usual and sounded normal, and then it would hesitate occasionall...
  • dougrainer's avatar
    Nov 09, 2023
    1. remove the gas orifice and blow out.
    2. Remove the metal exhaust cover and roll a golf ball down from the top. This will tell you if the flame exhaust tube has any restrictions(insect nests) which can cause your problem. You CANNOT see this and you use the golf ball to determine if obstruction.
    3. Make sure that you remove the burner flue and run a nylon brush thru it to remove any possible spider nest residue. The smallest residue can cause your problem.
    4. Last, proper air mixture is critical for your type problem. Adjust as needed to get a loud blue roaring flame. Doug
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
