Old-Biscuit
Apr 10, 2014Explorer III
The access panel were gas valve/burner and PRV is ALL you will see or be able to get too from there in that outside compartment.
The slowly lowering of hot water flow is due to the HOT water outlet check valve being plugged.
The HOT (and cold) water line is on the backside (inside rv) of the water heater tank.
You need to locate the access from inside rv.
Disconnect hot outlet line
Remove nipple on tank (check valve inside)
Replace with new check valve
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
