CRMW
May 21, 2016Explorer
Atwood Water Heater won't stay lit.
I have an Atwood GC6AA-10E Water Heater.  Since I got the trailer last summer, the hot water heater won't work on gas.  It will light, run for 2 or 3 seconds and turn off.  If I bypass the controls and hook up 12v directly to the gas valve it will run but the ignighter does not get red hot.  The flame ignighter/sensor appears to be in the right spot, and the flame appears weak.
So far I have:
Replaced the igniter/sensor - both work the same
Tightened all connections
cleaned the orifice
cleaned the flue and burner tubes
had the dealer verify the board
bypassed the ECO and Thermostat when testing and replaced them
used a bbq regulator hooked up directly to the gas valve
cleaned the gas valve with throttle body cleaner
verified the solenoid valves are working in the gas valve by checking them 1 solenoid at a time
Any ideas would help. It would be nice to have access to another gas valve to test it but I haven't been able to locate one.
Thanks for your time, Chris
So far I have:
cleaned the orifice
