Old-Biscuit
Sep 12, 2020Explorer III
RED Fault Light is triggered when flame fails to light and PROVE it lit
Flame Rectification ---milliamp signal generated
Spark electrode provides high voltage spark for ignition AND is return path for that milliamp signal
*Electrode must be CLEAN---soot/carbon removed using emery cloth
*High Voltage wire connection at transformer on circuit board clean/tight
*High Voltage wire not loose in the ceramic insulator
*Ceramic Insulator --no cracks--milliamp signal will go to ground and circuit board won't receive it
*electrode must be engulfed in flame
*spark gap 1/8" - 3/16"
When flame lights off......is flame BLUE and quiet (very slight roar)?
IF NO
Might need to adjust air shutter ---typically only needs to be roughly 1/4 open
Might need to clean orifice (soak in alcohol/air dry), clean burner tube (small bottle brush)
Is this a GAS Only Water Heater OR GAS/Electric Combo?
Gas only vs Combo use different wiring systems
So what is MODEL?
IF NO
So what is MODEL?
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
