Old-Biscuit
Sep 13, 2020Explorer III
"Model is GC6A-8E
Flame is more orange than blue.
There is a wire with what looks like a resistor in it, what is that for?"
8E has separate controls for electric & gas
ELECTRIC:
120VAC comes from a Circuit Breaker to on/off switch (backside of WH Tank) then thru set of T-stats to element (also backside of WH Tank)
GAS:
12VDC comes from Fused source to 'thermal cut out' (fuse in clear tubing----it blows at 190*F if flame blowback occurs and stops ALL DC to water heater. One shot device --replace if bad)
From thermal fuse DC goes to/thru TT-stat then to circuit board
Circuit Board then sends DC to ECO/Gas Valve AND spark electrode
Posted earlier
When flame lights off......is flame BLUE and quiet (very slight roar)?
IF NO (YOU stated more ORANGE then Blue)
Might need to adjust air shutter ---typically only needs to be roughly 1/4 open
Might need to clean orifice (soak in alcohol/air dry), clean burner tube (small bottle brush)
ELECTRIC:
GAS:
Posted earlier
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
