asptrader
Sep 20, 2020Explorer
I have a problem very much like what Paul1944 describes...
-- New Atwood Gas G6C-8E-SP water heater in my RV
-- When Remote Switch is switched on, light turns red, then off within 10 seconds usually
-- Water heater stays on for 10 to 30 minutes, then turns off
-- The Remote Switch light does NOT turn back on
-- I cannot turn light off and then back on for an hour or two
-- After the shutdown, the sink running water is definitely warmer for 10-15 seconds so I know the heater has heated water. I assume that means there is water in the tank.
-- I installed a new RV Water Heater Thermal Cut Off Switch Kit Replace for Atwood 93866 - understood that it probably wouldn't make a difference but installed it anyway. It doesn't appear to break after cutoff and water heater can restart sometime later (like an hour or two later)
-- I purchased a new Atwood 91447 Thermostat Assembly and can install it if that would make for a difference
Old-Biscuit wrote:
"Model is GC6A-8E
Flame is more orange than blue.
There is a wire with what looks like a resistor in it, what is that for?"
8E has separate controls for electric & gas
ELECTRIC:
120VAC comes from a Circuit Breaker to on/off switch (backside of WH Tank) then thru set of T-stats to element (also backside of WH Tank)
GAS:
12VDC comes from Fused source to 'thermal cut out' (fuse in clear tubing----it blows at 190*F if flame blowback occurs and stops ALL DC to water heater. One shot device --replace if bad)
From thermal fuse DC goes to/thru TT-stat then to circuit board
Circuit Board then sends DC to ECO/Gas Valve AND spark electrode
From Old-Biscuit earlier comments, I take it that I should pay anything to the follow... Anything else?
Posted earlier by Old-Biscuit
When flame lights off......is flame BLUE and quiet (very slight roar)?
IF NO (YOU stated more ORANGE then Blue)
Might need to adjust air shutter ---typically only needs to be roughly 1/4 open
Might need to clean orifice (soak in alcohol/air dry), clean burner tube (small bottle brush)
Old-Biscuit wrote:
"Model is GC6A-8E
ELECTRIC:
GAS:
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
