joelyn's avatar
joelyn
Atwood water heater?????
have a 2002 Atwood water heater model G6A-8E the same as listed below. first time for us using this trailer and flipped the switch to ignite the heater and fired right up. ran until it shut down and went to use the water but only luke warm water coming out. can't even use the cold water to mix because its to cold than.
figured i would go turn up the thermostat in the unit but when i went to look for it i don't see any type of dial to make the water hotter, nothing..... not even a valve to lite it manually.
are these just pre set to a certain temp and thats it or am i missing something to make the water hotter?
thanks
atwood water heater
