JBarca
Apr 19, 2019Nomad II
BFL13 wrote:
Does the stove work? If you didn't have the measuring device would you suspect anything is wrong with the stove?
Yes, the stove worked before as the main tank regulator was creating 10"WC which is what the stove is supposed to be working at. If I did not checked this, I would not have known I had a problem.
What I have seen in the past on these cheap regulators is, once they start to deteriorate in performance sooner or later the water heater and the furnace may act up without enough pressure to operate correctly. Or worse, the pressure goes way too high, beyond 14" WC and then you run into risk of overheating.
From my background, doing preventive maintenance with checking to correct things before they stop working, keeps you running longer.
It is just hard to believe I got 2 brand new Dometic regulators that do not regulate properly right out of the box. I'm hoping some others have run into this before to give me some clues what is going on. Maybe Dometic changed suppliers and they have a quality issue. Don't know, yet anyway.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
