dougrainer
Apr 20, 2019Nomad
1. I would indeed suspect the Dometic Stove reg's are bad. But, I doubt Dometic will fess up. It took months last year to get Dometic to agree that the Atwood Water heater Control boards on thousands of DSI water heaters were faulty. They then replaced them. Probably the same thing now. Their supplier has built faulty regulators and it will take time for the bad ones to show up in service centers before Dometic realizes the problem. You need to contac Dometic and explain in detail your testing process so they will understand that they are dealing with someone that knows RV LP systems. Hopefully they will want all your regulators back for testing. BTW, it is RARE got the Range/stove regulator to go bad. Usually they just leak. Doug
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
