rfaulkner99's avatar
rfaulkner99
Autoformer issue
Can someone with a Hughes Autoformer
tell me if it is normal to measure around 10 ohms of resistance between the hot and neutral prongs of the plug? I was expecting infinite resistance, so hoping to see if this is normal or not.
Initially I thought it was the plug, because there was some corrosion and melting on on the hot terminal, but I cut off the plug and the bare wire measures the same.
Thanks
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Cummins12V98 wrote:
    If you want a FACTUAL answer simply contact AutoFormer!
    THeir response was already up -thread
    For the person who ask. I'm not good at drawing with the computer and do not have the kind of tablet that would let me draw it.
    So I will describe
    I needed to, as I recall buck about 10 volts
    So it was a 10 volt transformer.. Primary connected to incoming power. I "Broke" one lead of the device's power transformer (A tube tester by the way) and put the secondary (10 volt) winding of the buck transformer in such a way that it was out of phase so it "Bucked" the incoming power.. Worked great Was able to dial the needel to the calibration mark every time.
    Simple really.
  • I don't know any company that is going to supply a schematic except to an authorized repair facility.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
