rfaulkner99's avatar
rfaulkner99
Autoformer issue
Can someone with a Hughes Autoformer
tell me if it is normal to measure around 10 ohms of resistance between the hot and neutral prongs of the plug? I was expecting infinite resistance, so hoping to see if this is normal or not.
Initially I thought it was the plug, because there was some corrosion and melting on on the hot terminal, but I cut off the plug and the bare wire measures the same.
Thanks
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
