RKW
Jul 13, 2021Explorer II
Old-Biscuit wrote:RKW wrote:
Thanks to those who chimed in on this thread. The comments are appreciated.
I did some more research and discovered that some pigtails, specifically those with the green knobs and sold by Camco, have a device located at the green knob that prevents a sudden large flow of gas in case of a broken gas line. LINK. It looks like mine is said Camco pigtail. I ordered a new pigtail and will replace the driver-side one. I'll post the results after I do this.
All ACME Nuts (Red/Green/Black----color just indicates Flow Ratings)) on pigtail have an 'Excess Flow Device' ...trips if flow downstream increases (leak)
But can also trip if the cylinder OPD valve is Opened too fast....close OPD/Wait 39 seconds/Open SLOWLY
Did you check that 30# Regulator on cross over line???
I've done the slow opening on the tanks dozens of times while troubleshooting the problem.
As far as the 30# Regulator, are you talking about the device located in the bay of the driver-side tank bay? I just noticed it last night. If replacing the pigtail doesn't solve the problem, I'll look at that next.
