teddyu
Apr 15, 2014Explorer
Here's a SWAG since the converter should work the same on shore power and generator. Are the Fleetwood Storms 30A? Or was the Shore Power 50A cable replaced with a 30A. OP says the unit is 30A. If this is possible, then on SP only one hot leg is getting power through the transfer switch but when on generator both hot legs are energized. Is the convertor on the possible dead leg? JM2¢...
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
