MEXICOWANDERER
Apr 30, 2014Explorer
To test a converter, make sure 120 volt power is actually GOING INTO the converter. This isn't the last of it. Read on...
12 Volts has to DEPART the converter. If you have an integrated system where the charging unit is part of the fuse panel you must INSURE the positive and the negative charge wires are connected electrically to the wires that go from the charger to the battery. Simply checking a receptacle, "Oh there's power, the converter must be bad" is insufficient troubleshooting. There are connections AT and WITHIN the converter that must be checked both visually AND with a meter. But a novice grade examination will have a perfectly good converter hurled out the back window and a small stack of currency hurled from the bank account. Your choice.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
