fischer
Apr 30, 2014Explorer
My converter is under the refer. you remove 2 screws and the wood panel comes off and the converter is behind it. The converter is held down with 4 screws. too remove power disconnect the hot side of the coach battery.
Since you were doing things to the batteries, the converter has 2 fuses on it you could check them.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
