ishouldbcamping's avatar
Jul 26, 2014
Aux battery
Hi, I just inherited a new to me camper but it doesn't have an aux battery. can someone tell me where on the converter to hook up the battery. is this an easy diy project or do I need an rv tech to do it ? I don't want to get hosed by an rv center, not that they would do anything like that:D thx for looking any help would be appreciated Ray
  • In all probability, your TC probably has a converter only, not a charger converter. My 1988 Bigfoot was without battery, and had an converter only. I upgraded to an AGM battery inside my TC, and replaced the converter with a 55 amp Smart Charger/Converter. I did my own install, and purchased my parts from Best Converter. You will find them very easy to talk to, and they will have several options for you.
    Wayne
  • Does it have an inverter already? If so, the battery connections are usually self explanatory, and the rest should already be connected properly. If not and you are going to buy an inverter, you have to consider the system requirements first, and then design and install your power system.
    This is simple if you understand charging systems, automotive wiring (including wire sizing and voltage drop), amperage draw, inverters, chargers, fuses, and circuit breakers, as well as shore power systems. If you don't and you DIY, you could cause yourself a lot of grief. But if you just drive into an RV service center, you could end up paying way too much for a simple system.
    Get together with a friend (or friend of a friend) who is good with automotive elec. systems, offer to pay a reasonable rate for time, try to get materials at cost, and go from there. Find out your truck alternator specs (consider an upgrade depending on system design), and analyze your 12v and 110v power needs before buying batteries, an inverter, and/or charger. Also you should consider a solar panel or two to keep the battery topped off. You should be able to charge the battery from the truck alternator with a small solar panel to keep it topped off, and run some small basic items like a coffee maker and lights with a small inverter.
    If you are going to try to power a microwave or small AC, you are going to be into an entirely different level of power requirements, you will need more batteries, and will need to be more careful about sizing your inverter. You wont have enough roof space for solar to do anything more than maintain your batteries.
    Good luck and feel free to email with specific questions once you decide what your system requirements are going to be.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 14, 2025
