Dr_Quick
Sep 14, 2014Explorer II
The only click that you should hear is from the right/front end, as that is the catch end. You may try this, if one of the springs is broken the shaft at that end will not have any tension on it. Use a vice grips or a channel lock and try and rotate shaft a bit a either end in both directions. If you do not feel any tension at that end in either direction, that is probably where the bad spring is.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 13, 2025
