wa8yxm
May 06, 2018Explorer III
One mine there is a SCREW in roughly the center to prevent just that from happening (The center of the track that is not the center of the awning)
But the other end moves or did till I screwed it as well.
TO move, you will need a partner or a step ladder, either one will work
Extend awning, have partner hold it up a bit, or use the ladder to hold it up and then from a DIFFERENT ladder, tug gently
If that does not move it then you will need to work along it pushing a bit
But I think a gentle tug shoudl work
once you have it properly centered. Roll up and insert screw like Damon did on mine.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
