We have 18ft Dometic power awning that something went snap in right about in the middle of the roller tube. When you hit the switch you can hear something slip and grind for a few seconds in the midd...
I think you'll find two springs. The manual awnings use two. My guess is that springs handle most of the weight and the motor "assists" the open/close cycles.
When we repaired an older A&E (now Dometic) manual awning, I pinned the ends with small nails. Cotter pins'd look nicer, but I don't think nails will fall out under all that torsion pressure. I remember one hole in the shaft and two grooves that the pin could pass through.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
