rbtglove's avatar
rbtglove
Awning Stuck Closed
The manual awning release lever will not move. Have tried turning the tube etc. but it just won't budge. Any ideas would be welcome. What kind of cost would be to have the 8' x 15'awning replaced. Should it be the whole works or just the tube?
  • Thanks - Chris - instuction worked first try - learn something even new after nearly 30 years RVing.
  • I've had that lever stick when the awning was extended, and the solution was to turn the tube just a bit in the direction it is going. So when down, turn the tube to further unroll as you flip the lever. Or when up, turn the tube slightly in the rollup direction. If that is what you mean you've already tried unsuccessfully, I got nothing.
    As for the cost, to replace, I've been quoted anyplace from $600 to $1000 for my 14 footer.
  • Release the arm at the bottom and swing it out while pulling on the lever.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
