dougrainer
Nov 07, 2013Nomad
Chris Bryant wrote:FreeRanger wrote:
Doug, I don't want the cintrol box. Just want to be able to put the awning in and out. I think the power went to the box which fed the switch.. With the box unhooked there is no power to the switch.
Yes- the switch will not work without the box. The switch controls the box, the box controls the awning. You can rewire with a different switch, you can figure out a set of control relays, but you cannot directly control the awning with that switch without the box.
You can use the same switch that controls a 5th wheel front landing gear. The wiring will also be the same. Doug
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
