dougrainer
Nov 08, 2013Nomad
SCVJeff wrote:dougrainer wrote:Those are the ones, and I've had trouble with both.SCVJeff wrote:
That also defeats all the fail-safe devices, and that becomes a liability for a shop to work on it, bla-bla..
You could probably make it work with a DPDT ON (mom)-OFF-ON (mom) rocker if that's a quest.
What Fail safe devices?????
The roof/arm wind sensor is an option and the Ignition interlock is an option. Doug
That comment relates to a warranty fix on the ignition interlock. They had problems chasing it down, I said 'pull it', they said 'can't'.
You are correct. IF under warranty, then do NOT modify any device on the RV, unless the OEM says to do it. Doug
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
